![]() | Home > Technical > Dash off question |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2657 ![]() ![]() ![]() |
I’ve not had a problem, 2002 TD5.
The odometer reading is via the ECU so that won’t ‘go missing’. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3486 ![]() ![]() ![]() |
Disconnect the battery first. If you have battery backup alarm, switch ignition on then off and disconnect battery within 15seconds.
Did not have issues with a 2009 Defender. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
No issue with disconnecting the cluster.
Odometer is stored in non-volatile memory in the cluster (not the ECU as stated above). ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17617 ![]() ![]() ![]() |
It is possible to replace the entire wiper system without disconnecting the IPAC or removing the dash panel if you remove all the fasteners and simply ease the dash panel away from the bulkhead. removing the dash is however not difficult (although quiet time-consuming) and makes the job more comfortable, though be advised you will inevitably find rust behind it, as well as other jobs you'll want to do at the same time.
If you're in a rush, don't remove the dash. If you have plenty of time and want to do the best job, remove the dash. Martin, for some reason I thought that the mileage was stored both in the IPAC and the ECM, to make it more difficult to "clock" a vehicle by swapping the IPAC. Am I imagining this? Thanks. |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 ![]() ![]() ![]() |
Thanks guys, sorry should of said its on a Puma.
Having to do this job in stages but have stripped everything to the point the dash is resting on just with the instrument cluster plugged in. Have noticed the red alarm light no longer comes on/flashes when I arm the alarm but the hazards flash three times still and the engine still starts okay so not sure what has caused that!?
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 334 ![]() ![]() ![]() |
It could be that the connector isn’t pushed home properly. Try unplugging it and plugging it in again.
It was a fuse. The same fuse does the clock, interior light and alarm light it appears!
