Home > Puma (Tdci) > Thread size cooling water Cylinder head
hornet
Does anyone know what thread size this is? It only needs to be drilled through and provides an ideal location (the warmest) to measure cooling water temperature coming out of the cylinder head. I guess some Ford-models have a sensor there, but I will not stick to genuine.
Post #978840 19th Jan 2023 4:30pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Interesting. My 2.2 does not have a threaded boss there. Roaming around 🇳🇴🇨🇭
Post #978854 19th Jan 2023 5:17pm
hornet
Cost saving measure. I guess the 2.4 part woud fit anyway
Post #978883 19th Jan 2023 7:01pm
Ianh
Interesting idea... so what’s the plan to use the input from the newly installed water temp sensor ?
Ps Given your question I’m assuming it’s already treaded. So it’s likely be metric, so having a look at the size and trying a couple of bolt sizes should give you the answer.
Post #978901 19th Jan 2023 9:09pm
hornet
Yes, it already has a thread, but it doesn't seem to be metric to me. If necessary, i'll cut it to fit my needs. I'm basically interested in the water temperature, the temperature output via the CHT is calculated, which i find a bit suspicious Confused
I already measure oil pressure and oil temperature, but i'm now planning to add a pyrometer (inside a intermediate mounting flange in front of the turbocharger) and the water temperature at the warmest point.
I still have a sports car that includes these measurements from the factory and i feel more comfortable there Very Happy
Post #978930 20th Jan 2023 7:49am
Martin
Site Admin
Is it a boss for a sensor or a threaded boss for fitting a cover or mounting something else (not in the LR application)?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #978934 20th Jan 2023 8:17am
hornet
It's a threaded boss, the only additional work that has to be performed is to drill into the pipe ("open it") and mount an applicable sensor. I am convinced it is a FORD-application for a sensor, no cover etc.
I think it's best to do it on the workbench, one could do it in situ with engine running as well I think....would worry about the chips then.
Post #978965 20th Jan 2023 12:40pm
hornet
My fault, I found a picture that shows a cover mounted on that boss.
But still think it should work for a sensor Very Happy
Edit: It is a standard M8 (M8 x 1,25 mm) thread and I wonder if it will show moreless correct temperature even withot connecting it directly to the cooling water.
Post #978967 20th Jan 2023 12:48pm
