Home > Puma (Tdci) > Thread size cooling water Cylinder head |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Interesting. My 2.2 does not have a threaded boss there. Roaming around 🇳🇴🇨ðŸ‡
19th Jan 2023 5:17pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
Cost saving measure. I guess the 2.4 part woud fit anyway
19th Jan 2023 7:01pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1972 |
Interesting idea... so what’s the plan to use the input from the newly installed water temp sensor ?
Ps Given your question I’m assuming it’s already treaded. So it’s likely be metric, so having a look at the size and trying a couple of bolt sizes should give you the answer. |
19th Jan 2023 9:09pm |
Yes, it already has a thread, but it doesn't seem to be metric to me. If necessary, i'll cut it to fit my needs. I'm basically interested in the water temperature, the temperature output via the CHT is calculated, which i find a bit suspicious
I already measure oil pressure and oil temperature, but i'm now planning to add a pyrometer (inside a intermediate mounting flange in front of the turbocharger) and the water temperature at the warmest point. I still have a sports car that includes these measurements from the factory and i feel more comfortable there |
20th Jan 2023 7:49am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6602 |
Is it a boss for a sensor or a threaded boss for fitting a cover or mounting something else (not in the LR application)? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
20th Jan 2023 8:17am |
It's a threaded boss, the only additional work that has to be performed is to drill into the pipe ("open it") and mount an applicable sensor. I am convinced it is a FORD-application for a sensor, no cover etc.
I think it's best to do it on the workbench, one could do it in situ with engine running as well I think....would worry about the chips then. |
20th Jan 2023 12:40pm |
My fault, I found a picture that shows a cover mounted on that boss. But still think it should work for a sensor Edit: It is a standard M8 (M8 x 1,25 mm) thread and I wonder if it will show moreless correct temperature even withot connecting it directly to the cooling water. |
20th Jan 2023 12:48pm |
