Home > Technical > Existing work light switch feed
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Hi all , my defender 2011 had a rear work light fitted when I bought her and it has never worked , I’ve been trying to trace the wires from the switch to the fuse but I’m struggling to find where they go , not sure if it’s an optional extra on a puma as there is also a switch in the rear for the light so thinking it’s a 2 was system ? , any one also have this ? , here is a pic of the front switch , rear switch is the same .
🥟 stew
Post #978341 16th Jan 2023 2:30pm
Totally aftermarket, I'm afraid, so you'll have to trace them the traditional way by taking things apart and looking.
Post #978348 16th Jan 2023 3:07pm
^^^^ I don't know.... that could be a Friday afternoon Speial Vehicles addition! Rolling with laughter
Post #978369 16th Jan 2023 4:44pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
So good of Land Rover to leave the choke hole in place after all these years as a convenient place to fit a switch.
As far as the rear work light is concerned it'll be a case of trace the wires, I'd start at the light and work forward as you have 2 switches.
Post #978545 17th Jan 2023 3:18pm
nicolas0505
France
You should do a continuity test with a multimeter.
Post #978552 17th Jan 2023 3:43pm
stew 46
I’ll try and trace the wires from the switch as there’s no feed getting to them , if no luck I’ll fit a new small fuse box under the front seat and start from scratch Thumbs Up
But suffering from a man cold at the moment and feeling like 💩💩💩
Post #978555 17th Jan 2023 3:58pm
TexasRover
Yes I was wondering the same. There is a rubber plug for that hole, but last time a defender had a choke fitted must have been 1991? Never changed the injection molding...you think that be cheaper than making and fitting a plug instead
Post #978583 17th Jan 2023 6:09pm
