![]() | Home > Puma (Tdci) > Another wiper issue |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
You should be looking at Fuse 11 on a 2011. Fuse 9 is on the very early Pumas (2007) before the wiper supply was relayed.
simon211 Member Since: 15 Jan 2023 Location: West Berkshire Posts: 4 ![]() ![]() ![]() |
Thank you for your reply Martin.
The fuse board cover doesn’t agree with you, though it may have been changed. ![]() Click image to enlarge I will check fuse 11. |
Label YQS500390 is for chassis VIN up to 7A752618 (early Pumas)
Your correct label is LR012449 (sorry no pic available online) Your fuse box cover has been replaced at some point with one from an early Puma. ![]() ![]() |
This is closer if not correct - see 9 and 11 are swapped.
![]() Click image to enlarge ![]() ![]() |
Thanks again Martin, I’ll check the fuse layout more thoroughly when my next attempt resumes 😄
Thanks again Martin...fuse 9 had 'popped' and has now been replaced; the wipers now operate.
I have the correct fuse chart being delivered tomorrow ![]() |
Thanks for coming back and saying that was it
