Home > Puma (Tdci) > Another wiper issue
simon211
United Kingdom 2011 Defender 110 Puma 2.4 USW Auto Alaska White
Another wiper issue
I wonder if anyone can help...wiper worm drive boxes replaced, wiper park switch replaced, wiper motor is proven good, wiper drive line replaced...grease applied liberally.
There's no power to the wiper switch but the fuse F9 is good. I'm having difficulty in working out what the 'A4' joint is in the diagram and so I don't know where it is nor what to look for.
Thank you in advance, for any information offered.
Post #978219 15th Jan 2023 5:13pm
Martin
Site Admin
You should be looking at Fuse 11 on a 2011. Fuse 9 is on the very early Pumas (2007) before the wiper supply was relayed.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #978228 15th Jan 2023 6:02pm
simon211
Thank you for your reply Martin.
The fuse board cover doesn’t agree with you, though it may have been changed.
I will check fuse 11.
Post #978236 15th Jan 2023 7:09pm
Martin
Site Admin
Label YQS500390 is for chassis VIN up to 7A752618 (early Pumas)
Your correct label is LR012449 (sorry no pic available online)
Your fuse box cover has been replaced at some point with one from an early Puma.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #978241 15th Jan 2023 7:24pm
Martin
Site Admin
This is closer if not correct - see 9 and 11 are swapped.
2015 D90 XS SW
Post #978242 15th Jan 2023 7:29pm
simon211
Thanks again Martin, I’ll check the fuse layout more thoroughly when my next attempt resumes 😄
Post #978245 15th Jan 2023 7:36pm
simon211
Thanks again Martin...fuse 9 had 'popped' and has now been replaced; the wipers now operate.
I have the correct fuse chart being delivered tomorrow Very Happy
Post #978592 17th Jan 2023 7:50pm
Martin
Site Admin
Thanks for coming back and saying that was it Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #978645 18th Jan 2023 11:50am
