Home > Tdi > Coolant temp sensor
mini Anaconda
Coolant temp sensor
I'm thinking of fitting a better temp gauge which actually has some numbers on it!
I have a 200 tdi out of a Disco in my Ninety and understand the sensor has a different thread than the Tdi in a Defender.
Does anyone know the thread size for the Disco Tdi sensor? BORG - Bucks & Oxon 4x4 Response Group
Post #978080 14th Jan 2023 8:13pm
mini Anaconda
Seems like its M16x1 thread, a thread no one else seems to use!
Although I have found out that PRC6663 should fit and make the gauge more accurate due to the Disco sender and gauge not being compatible. BORG - Bucks & Oxon 4x4 Response Group
Post #978407 16th Jan 2023 7:53pm
Martin
Site Admin
Yes the 200 Tdi Disco spec engine has an M16x1.0 coolant sensor thread.
PRC6663 is M16x1.0, and is from the late 2.5 engine range (12J/19J/17H) so it's the correct match for a Defender gauge.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #978416 16th Jan 2023 8:43pm
mini Anaconda
Thanks Martin. Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #982956 18th Feb 2023 9:27pm
