![]() | Home > Tdi > Coolant temp sensor |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 801 ![]() ![]() |
Seems like its M16x1 thread, a thread no one else seems to use!
Although I have found out that PRC6663 should fit and make the gauge more accurate due to the Disco sender and gauge not being compatible. BORG - Bucks & Oxon 4x4 Response Group ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Yes the 200 Tdi Disco spec engine has an M16x1.0 coolant sensor thread.
PRC6663 is M16x1.0, and is from the late 2.5 engine range (12J/19J/17H) so it's the correct match for a Defender gauge. ![]() ![]() |
Thanks Martin.
