![]() | Home > Off Topic > Eon and Smart meters |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3396 ![]() ![]() |
Not quite correct, even the new smart meters don't read in kwh they read in cubic metres.
Other information is required to convert a cubic meter value into kwh and this isn't available at the meter (it's the calorific value of the gas on a given day). The kwh value is therefore calculated by your suppliers billing system after it receives the reading from the meter. Where there might be a difference is where your old meter read in "hundreds of cubic feet". ![]() |
For info, Eon and Octopus actually use the same IT and billing systems ![]() ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5870 ![]() ![]() |
If I press the readout button on my smart meter it gives a figure followed by kWh.
I have to press a series of buttons on mine to give cubic meters. It is not the standard display figures. Last edited by landy andy on 10th Jan 2023 11:47pm. Edited 1 time in total |
Yep, thats an estimate based on a typical calorific value.
The calorific values of gas for each region are published daily and feed into supplier billing systems to ensure the correct kwh are billed. ![]() |
But you can talk to octopus and website is brilliant, it also gives me the option to change my direct debt as I wish. They also appear to honest unlike Eon. |
And that is what people believe/read/provide as a meter reading which is why their bills can massively out. |
Not quite as the calorific value only varies by fractions of a percent each day.
If you've used 100 cubic meters of gas since the last read, that's what the meter will tell you and what customers with non smart meters will supply as a reading. The calorific value doesn't affect the reading. Whilst not exclusively so, you're much more likely to have an issue with an old manually read meter than a smart meter. ![]() |
1 m3 = 10.55 kWh basically
The meter displays 1055 and that is given as a meter reading, but unknown to the custom that it’s kWh, the meter reading should be 100, as that is the cubic meter amount. That is general but I’ve found many old people who don’t trust smart meters so they give the meter displayed info to the billing company causing confusion and high bills. |
Just to make you all feel better, by 2026, all domestic and commercial electricity supplies will be settled across the industry on a half hourly basis so expect a huge push from the suppliers over the next 2 years to a) get even more smart meters installed and b) request consent to read your meter every half hour.
Customers who elect to stay on non smart meters will have their half hourly profiles estimated based on industry averages.... What sort of tariffs the existing suppliers decide to introduce to make use of this data is still to be determined. ![]() |
Sjmmarsh Member Since: 01 Jan 2023 Location: Lincs Posts: 59 ![]() ![]() ![]() |
If you think your gas consumption has gone up massively after a new SM, check that the old meter wasn’t so old it was showing 100 cubic feet as a unit of consumption…
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2231 ![]() ![]() ![]() |
What's the logic behind the 30min readings?? Just sounds like more fuel to the 'smart meter' conspiracy rabbit hole... ![]() |
It's to allow suppliers to bill different rates for different specific times of day and potentially be able to do this dynamically. This is how suppliers will be billed by the distributors going forward.
If there is very little demand between say midnight and 3am, it makes sense to run some items at this time. Being able to measure how much a customer uses in those specific half hours allows them to benefit from the cheaper electricity. On a current single rate meter, customer.might be paying 35p/kwh for all usage whereas the actual cost might only be 3p st certain times of day. Without half hourly reads there is no way to.benefit from this. Customers don't have to elect to be billed like this (yet) but it is one way of smoothing demand out across the day and reducing the extra generation and distribution capacity required to satisfy the increasing load on the network. ![]() Last edited by camelman on 11th Jan 2023 11:36pm. Edited 1 time in total |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
^ Probably charging extra for peak time use.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
Thanks for the replies chaps. My mum is going to go through previous bills and get info together and then will speak to Eon to discuss.
Shell keep pestering me for replacement meters.... I will be taking pictures of meters before they get swapped out. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
