Home > Puma (Tdci) > Loud roaring sound around the intake area
kirgitrover
Kenya 2010 Defender 110 Puma 2.4 SW Keswick Green
Hello fam, I have this roaring sound coming out of air intake puma 2.4.
It's a bit noisy from the driver side. However the car has power though sometimes I lose it which make me turn of the engine and start again.
What might be the issue.
Post #977310 10th Jan 2023 5:37am
Co1
Sounds like a burst intercooler or intercooler hoss. Pretty common issue.
Post #977312 10th Jan 2023 6:14am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Check that the air filter cover is properly seated and clipped in place. A loose cover can cause a quite significant roaring noise.
Post #977324 10th Jan 2023 8:47am
It could also be that the turbo modulator has failed and the turbo is stuck in the full boost vane setting. This happened to me on one occasion (as a result of the engine harness chafing problem) and the result is spectacular - the air intake sounds like a Vulcan at take-off, small children and old folk would run for cover as I accelerated, and the power was awesome, at least until an overboost triggered the MIL and put the engine in limp mode.
It is truly startling how much induction noise there is with the turbo on full boost, so well worth checking.
If the turbo actuator is working correctly, the link between the actuator and the turbo should park with the engine off in mid position. If it is at either extreme, then you have a stuck or malfunctioning actuator (as I recall lowest position is full boost). If it is at mid position it doesn't mean that it is working, but if it isn't there definitely is a problem.
If a boost pipe has split, the noise tends to be a loud farty noise or sometime a whistle. The turbo stuck on boost sounds more like a jet engine.
Post #977344 10th Jan 2023 11:45am
Whilst posters above may well be true BW’s explanation just above is very accurate as I’ve known similar before.
Often the linkage over time can become sticky too which can mean the EA fails to operate and then gets stuck open.
I put a little 3 in 1 oil on the two linkages on the turbo and that has meant I’ve not had the issues again since.
As as BW mentioned, it will trigger limp mode and MIL (amber dash light) and is not something you want to happen either.
A hose split is a possibility though of course too, in particular check the one just above the steering column as this can rub on the hose they are very close as standard anyway. $W33T $0U7H3RN $UG4R
Post #977411 10th Jan 2023 5:11pm
Julie
Post #977467 10th Jan 2023 7:57pm
spudfan
Ireland
Had this after a service. The maindealer mechanic had not closed the top off the airfilter box correctly. Once closed correctly the roaring noise sound went. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #977506 10th Jan 2023 10:08pm
kirgitrover
Air filter cover is tight.
Sounds like this...
[https://youtu.be/r2HdXnl6AH8]
Post #977534 11th Jan 2023 7:23am
Vago487
England 2012 Defender 90 Puma 2.2 HT Firenze Red
Had similar symptoms to this a few weeks ago, unfortunately all the usual fixes of replacing boost pipes/intercooler etc.... didn't solve the issue. It turned out to be one of the 8 rubber gaskets that seal the inlet manifold to the block had split causing a leak on boost.
Post #977572 11th Jan 2023 12:46pm
