Home > Tdi > 200TDI Thermostat top cover bolts.
mini Anaconda
After a bit of a struggle I got all three bolts out, well, the head broke off one but managed to wind the remnants out with a set of grips. Is it a wise idea to use stainless bolts or should I just use standard ones with plenty of anti seize paste on them?
Many thanks. BORG - Bucks & Oxon 4x4 Response Group
Post #977028 7th Jan 2023 9:00pm
Retroanaconda
Don’t use stainless, it’ll be even worse for bi-metal corrosion. New good quality bolts - not cheap ones off eBay - and a bit of anti-seize paste as you suggest is the best option.
Post #977029 7th Jan 2023 9:03pm
mini Anaconda
Many thanks, Retro. BORG - Bucks & Oxon 4x4 Response Group
Post #977031 7th Jan 2023 9:26pm
