200TDI Thermostat top cover bolts.
After a bit of a struggle I got all three bolts out, well, the head broke off one but managed to wind the remnants out with a set of grips. Is it a wise idea to use stainless bolts or should I just use standard ones with plenty of anti seize paste on them?
Many thanks.BORG - Bucks & Oxon 4x4 Response Group
7th Jan 2023 9:00pm
Retroanaconda
Don’t use stainless, it’ll be even worse for bi-metal corrosion. New good quality bolts - not cheap ones off eBay - and a bit of anti-seize paste as you suggest is the best option.
7th Jan 2023 9:03pm
mini Anaconda
Many thanks, Retro.BORG - Bucks & Oxon 4x4 Response Group
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
