Home > In Car Electronics > Problem lights
Poulstonb
Problem lights
Evening all
I’ve installed new Osram led headlights with angel eye DRL
I’ve an issue with one of the lights…….
With Side lights on angel eye comes on both
Then put on main beam angel eye stays on both plus headlight
Then put on full beam and the angel eye goes out on one of the headlight
Switch back to main beam and side light leaving only one of the angel eyes on. Could this be a switch back issue with the headlights?
Post #976688 4th Jan 2023 6:01pm
Poulstonb
Post #976720 4th Jan 2023 9:58pm
I'd hazard a guess that your vehicle is fitted with dim dip and it's this system that's creating the issues with your LEDS. Find the large resistor under the drivers wing somewhere in front of the aerial and unplug it, to see if I'm right. Darren
Post #976835 5th Jan 2023 9:11pm
Poulstonb
Thanks for the reply
What’s dim dip and how would I know if my vehicle has it ?
Post #976836 5th Jan 2023 9:28pm
Dim dip was a (largely pointless) safety feature introduced in the 90's whereby the headlights are made to glow when the side lights are on and the engine is running. This is achieved by running the dipped beam bulbs filaments on a reduced voltage by way of a large resistor. Not only did this reduced voltage shorten the life of regular halogen bulbs, it plays havoc with LED's. Darren
Post #976841 5th Jan 2023 9:58pm
Poulstonb
Definitely didn’t have dip dim before led install .
Post #976866 6th Jan 2023 8:13am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Have you swapped the headlights left to right to see if it is a fault with the light units or if it's a wiring fault? Do that first then report back.
Post #976882 6th Jan 2023 10:22am
Poulstonb
Eureka !!!
Problem with switch back function on one light , company are changing unit for me .
Thanks for suggestions 😀
Post #976886 6th Jan 2023 10:49am
