Home > In Car Electronics > Problem lights |
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88 |
Click image to enlarge |
4th Jan 2023 9:58pm |
I'd hazard a guess that your vehicle is fitted with dim dip and it's this system that's creating the issues with your LEDS. Find the large resistor under the drivers wing somewhere in front of the aerial and unplug it, to see if I'm right. Darren
5th Jan 2023 9:11pm |
Thanks for the reply
What’s dim dip and how would I know if my vehicle has it ? |
5th Jan 2023 9:28pm |
Dim dip was a (largely pointless) safety feature introduced in the 90's whereby the headlights are made to glow when the side lights are on and the engine is running. This is achieved by running the dipped beam bulbs filaments on a reduced voltage by way of a large resistor. Not only did this reduced voltage shorten the life of regular halogen bulbs, it plays havoc with LED's. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 6th Jan 2023 11:59pm. Edited 1 time in total |
5th Jan 2023 9:58pm |
Definitely didn’t have dip dim before led install .
6th Jan 2023 8:13am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 319 |
Have you swapped the headlights left to right to see if it is a fault with the light units or if it's a wiring fault? Do that first then report back.
6th Jan 2023 10:22am |
Eureka !!!
Problem with switch back function on one light , company are changing unit for me . Thanks for suggestions 😀 |
6th Jan 2023 10:49am |
