![]() | Home > Maintenance & Modifications > Wiper's packed up |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
99% certain it will be the park switch mine went and blew fuses the exact way yours did cheap fix tho and only about half an hour to do on my td5
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 181 ![]() |
Agree 👍 park switch Had the same problem with mine as well a few months back
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 794 ![]() ![]() ![]() |
Hi,
Have you tried moving them by hand? If yours has the nylon gear wheels and they are worn, it can jam the rack and it will also stop the motor and blow the fuse- I have had exactly that previously. Chris |
