Home > Maintenance & Modifications > Wiper's packed up
Charles_R
Wiper's packed up
Was coming home from up north on the eve of Christmas eve in the rain, wipers on full blast for the last 40 mins.
suddenly, poof they stop in the middle of the windscreen. Get to the services, fuse blown, tried and a new one and it blew immediately. Waited a couple hours and tried it again and it worked fine.
Not been tempted to switch it back on full blast since, I hope I don't need to replace the whole motor but that seems like the obvious solution. The wipers have also never returned to the correct park place so could it just be that switch?
Post #975916 28th Dec 2022 10:05pm
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
99% certain it will be the park switch mine went and blew fuses the exact way yours did cheap fix tho and only about half an hour to do on my td5
Post #975959 29th Dec 2022 11:15am
ak615
Agree 👍 park switch Had the same problem with mine as well a few months back
Post #975970 29th Dec 2022 1:24pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Wipers
Hi,
Have you tried moving them by hand?
If yours has the nylon gear wheels and they are worn, it can jam the rack and it will also stop the motor and blow the fuse- I have had exactly that previously.
Chris
Post #976101 30th Dec 2022 6:19pm
