![]() | Home > Technical > Adding CL to a 2010 110 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2155 ![]() ![]() |
The central locking is controlled by the 10AS or ALM ECU. For a 2010 2.4 Puma I expect you have a Lucas (Green) 10AS unit. For central locking it needs to be the right 10AS unit with the additional NEC relay and varistor fitted. If your current one does not have theses, which is likely if it was not equipped with Central locking from the factory, then you can have it upgraded by Technozen https://www.technozen-electronics.co.uk/la...-services/ or you can get the components off them and do yourself.
Once done you will need to program the 10AS and fobs with a Nanocom, IIDTool etc to get all working correctly. NB. The CCF for a Puma is used between the ECU and instrument cluster via a can bus. The 10AS communicates to the Engine ECU and the Instrument cluster via a proprietary serial bus so does not use a CCF as such. |
Cam-Tech-Craig Member Since: 27 Nov 2022 Location: Cam Posts: 19 ![]() ![]() ![]() |
Thank you Ian, that's super kind sir...
Had the box returned today and it works!!! YAY...
Thanks to all on here for your help ![]() ![]() |
