Home > Technical > Adding CL to a 2010 110
Cam-Tech-Craig
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi all, Merry Christmas!
I’m adding CL to my 2010 110 puma pickup. I purchased a kit on here but am struggling to find a CCF to change/initiate the factory remote to lock the newly fitted CL kit… Has anyone done this? Can anyone give me some pointers on the CCF that needs changing please???
Post #975810 27th Dec 2022 3:15pm
Ianh
The central locking is controlled by the 10AS or ALM ECU. For a 2010 2.4 Puma I expect you have a Lucas (Green) 10AS unit. For central locking it needs to be the right 10AS unit with the additional NEC relay and varistor fitted. If your current one does not have theses, which is likely if it was not equipped with Central locking from the factory, then you can have it upgraded by Technozen https://www.technozen-electronics.co.uk/la...-services/ or you can get the components off them and do yourself.
Once done you will need to program the 10AS and fobs with a Nanocom, IIDTool etc to get all working correctly.
NB. The CCF for a Puma is used between the ECU and instrument cluster via a can bus. The 10AS communicates to the Engine ECU and the Instrument cluster via a proprietary serial bus so does not use a CCF as such.
Post #975812 27th Dec 2022 4:14pm
Cam-Tech-Craig
Thank you Ian, that's super kind sir... Bow down Thumbs Up
Post #975906 28th Dec 2022 7:51pm
Cam-Tech-Craig
Had the box returned today and it works!!! YAY...
Thanks to all on here for your help Bow down Thumbs Up
Post #978914 20th Jan 2023 12:10am
