Home > Wheels & Tyres > Are 265/75/16 ok swap for 235/85/16
Stacey007
Hello
About to buy some new tyres.
Currently std continental 235/85/16
Looking at 265/75/16
Will these be ok?
Post #974522 13th Dec 2022 11:25am
Yes, they're essentially the same diameter and are a common alternative fitment. They were the standard size on some 90's for a while. Depending on your wheels, you may need to adjust the lock stops slightly to prevent rubbing on the radius arms. Darren
Post #974523 13th Dec 2022 11:31am
geobloke
As above. During TD5 era 265/75/16 BFG AT became an option on Boost alloys.
Post #974526 13th Dec 2022 11:37am
Stacey007
Thanks both Smile
Post #974539 13th Dec 2022 12:55pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Just be warned, if fitting these to the same rims you will likely lose some turning lock. That is assuming the lock stops were 'optimised' for the original tyres.
Post #974617 14th Dec 2022 5:54am
rustandoil
The ride improved significantly when I did this swap on my 110
Post #974618 14th Dec 2022 7:03am
