Home > Wheels & Tyres > Are 265/75/16 ok swap for 235/85/16 |
Yes, they're essentially the same diameter and are a common alternative fitment. They were the standard size on some 90's for a while. Depending on your wheels, you may need to adjust the lock stops slightly to prevent rubbing on the radius arms. Darren
13th Dec 2022 10:31am |
As above. During TD5 era 265/75/16 BFG AT became an option on Boost alloys.
13th Dec 2022 10:37am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3776 |
Thanks both
13th Dec 2022 11:55am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
Just be warned, if fitting these to the same rims you will likely lose some turning lock. That is assuming the lock stops were 'optimised' for the original tyres.
14th Dec 2022 4:54am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 757 |
The ride improved significantly when I did this swap on my 110
14th Dec 2022 6:03am |
