![]() | Home > General & Technical (L663) > Folding mirrors |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
or they get programmed to stay out I have no reason for them to fold
tooslo964 Member Since: 25 Jun 2020 Location: Aberaeron Posts: 42 ![]() ![]() |
Appreciate that, I was wondering if there was a way to stop them folding as opposed to defrosting them So surmising the answer is a no ![]() |
Hi there, thanks for that,
A lot of googling and it looks as if it's programmable feature only |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3028 ![]() ![]() |
So, if the mirrors are frozen l assume they are designed such as the mechanism won't be damaged by the attempt to move them.
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 ![]() ![]() ![]() |
There’s a bit in the iGUIDE that states that if a mirror folded out is knocked or manually folded then the mechanism disengages to avoid damage to the motor. Unsure if it works the other way too but it’s possible. https://instagram.com/bentheoandrews
Well, you'd hope so or there'll be a lot of warranty claims !!
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3456 ![]() ![]() |
Seems odd that a simple function can’t be disabled. 24MY 90 D250 HSE, Tasman Blue
May I suggest a pair of mirror bags/mits might help you gents out https://www.ebay.co.uk/itm/124000340053 or https://www.amazon.com/lebogner-Waterproof...B081ZJVG74
Or you could find a couple of bags to place over your mirrors. With the Freelander 2 I have the same problem and find that a squirt of silicone spray around the folding joint helps no end in preventing icing up. |
Thanks for that, will give the silicone a go.
Frustrating, can start and warm car remotely, then either have to faff around sorting mirrors or drive off without |
Seems to have done no harm to mine. had to fold/unfold them to get the mechanism to re=engage. Think that's mention in the manual |
