Home > General & Technical (L663) > winter problems
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
winter problems
Morning 2 problems spotted this morning with my 90 after a hard ice
I used the remote start this morning set to high which worked OK but noticed it did not activate the heated windows is there a way of changing this as the wipers were still frozen
Also the mirrors folded in and froze wondering if there is a way to stop them doing this when locking the vehicle
Simon
Post #974344 12th Dec 2022 10:57am
defender_auug
United States
there is a setting for auto on for the heating windshield and defrost - this should do it
Post #974663 14th Dec 2022 5:46pm
LR Nuts
I have heated seats (front).
I have heated front screen.
I don't have heated windscreen washer jets ???
Called into local dealer, as I was passing ............. they didn't want to know !!!
I was asked the question "Did we supply the vehicle"
NO I replied. I can only presume they want to help 'their customers' and not other Dealer Nettwork.
THANK YOU LANDROVER !!!!!
The last time I had a vehicle that did NOT have heated washer jets ....... was in the 1980's
Post #974665 14th Dec 2022 6:02pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I bet it wasn't a Land Rover you owned in the 80's - that certainly would not have had heated washer jets. Rolling with laughter
Post #974669 14th Dec 2022 6:36pm
lightning
lf it's not got the heated washer jets, why is it the dealers issue?
lf the vehicle was supposed to have them then you could try an email to Land Rover but it's not so easy to retrofit parts as it was on the old Defender.
My 90 Commercial hasn't got the interior tailgate release switch, and so far nobody has been able to do anything about it, it's not just a case of fitting a switch apparently it's not programmed in the BCM either.
Post #974675 14th Dec 2022 7:20pm
whiterdesign
Heated jets are part of the cold climate pack, which isn’t standard, has to be speced at build 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #974703 14th Dec 2022 11:06pm
LR Nuts
Yes I know that, but I bought second-user.
Cold Climate Pack should be for vehicles in Canada, Iceland, Scandinavia, Russia ...... NOT Blighty !
So what LR saved in Pence, is going to cost me in POUNDs to retro fit.
Post #974727 15th Dec 2022 10:21am
Buz1500
Or you could just use some winter washer fluid rated to -20……
Post #974728 15th Dec 2022 10:49am
Retroanaconda
No issues with frozen jets here in the highlands despite sub-zero temperatures. No need for heated jets, and given they are mounted on the wiper arms I’m not sure how they would work.
As above proper washer fluid is all you need unless you’re in the arctic or something.
Post #974730 15th Dec 2022 10:51am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Re: winter problems
I seem to have this problem also, mine are both switched to come on automatically in the Pivi Pro settings but when I start my car remotely they don't switch on until I unlock my car and actually get in. When the car is started remotely the Pivi screen remains off and none of the switchgear underneath the screen is lit up, it only 'boots' up when I unlock the car no matter how long the car has been running. Are other people seeing a different result if they start remotely? If I just jump in on a cold morning the front and rear screen both come on immediately. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #975148 19th Dec 2022 4:40pm
J77
My one no longer puts the blowers on, my 90 went the same way. 24MY 90 D250 HSE, Tasman Blue
Post #975155 19th Dec 2022 5:52pm
whiterdesign
Mine definitely switches on the front windscreen when I remote start. Don’t know about the rear as that never freezes due to where I park it. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #975162 19th Dec 2022 7:12pm
lightning
Well, l don't have remote start but it's nice to have a vehicle where the locks don't freeze up in sub zero temperatures.
On my 2005 Defender l had to warm the door locks with a hairdryer before l could get in.
Post #975164 19th Dec 2022 7:23pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
You do have remote start! You just don’t have the scheduled remote start. Pretty sure all new Defenders have it. Mine has it and yeah, only the blowers come on - not heated windscreen. https://instagram.com/bentheoandrews
Post #975170 19th Dec 2022 8:49pm
Tim in Scotland
This is all interesting because I have a 2020 D240 First Edition and it has remote starting from the app where I can set how warm I want the car to try to warm to (never gets there within the 30 minutes preconditioning time). It always demises/defrosts both the front and rear screens and both wing mirrors.
I also have an all electric Mini……….. half the price of the Defender and in addition to defrosting ALL the windows and sunroof it has heated washer jet nozzles, mirrors and in preconditioning mode it heats the steering wheel and both front seats but not to as high a temperature as when I switch them on manually but at least the leather isn’t freezing cold to sit on and it does all of this in 22 minute and reduces my electric range by 2 miles if not plugged into a charger. There is no heated front screen in it but it uses a very efficient heat pump to blow warm air into the cabin and while the temperature is fixed it is set at 23C which is jolly toasty on a freezing morning.
In 2011 I had an Evoque that had instant heating for the cabin as it used a PTC heater not scavenged heat from the engine bay just in those days there was no remote start to start it all off before you started the engine. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #975213 20th Dec 2022 9:52am
