Home > General & Technical (L663) > winter problems |
defender_auug Member Since: 23 Oct 2020 Location: Chicago Posts: 53 |
there is a setting for auto on for the heating windshield and defrost - this should do it
14th Dec 2022 4:46pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1172 |
I have heated seats (front).
I have heated front screen. I don't have heated windscreen washer jets ??? Called into local dealer, as I was passing ............. they didn't want to know !!! I was asked the question "Did we supply the vehicle" NO I replied. I can only presume they want to help 'their customers' and not other Dealer Nettwork. THANK YOU LANDROVER !!!!! The last time I had a vehicle that did NOT have heated washer jets ....... was in the 1980's |
14th Dec 2022 5:02pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 |
I bet it wasn't a Land Rover you owned in the 80's - that certainly would not have had heated washer jets.
14th Dec 2022 5:36pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2897 |
lf it's not got the heated washer jets, why is it the dealers issue?
lf the vehicle was supposed to have them then you could try an email to Land Rover but it's not so easy to retrofit parts as it was on the old Defender. My 90 Commercial hasn't got the interior tailgate release switch, and so far nobody has been able to do anything about it, it's not just a case of fitting a switch apparently it's not programmed in the BCM either. |
14th Dec 2022 6:20pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
Heated jets are part of the cold climate pack, which isn’t standard, has to be speced at build 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
14th Dec 2022 10:06pm |
Yes I know that, but I bought second-user.
Cold Climate Pack should be for vehicles in Canada, Iceland, Scandinavia, Russia ...... NOT Blighty ! So what LR saved in Pence, is going to cost me in POUNDs to retro fit. |
15th Dec 2022 9:21am |
Buz1500 Member Since: 07 Jul 2020 Location: Cumbria Posts: 150 |
Or you could just use some winter washer fluid rated to -20……
15th Dec 2022 9:49am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2671 |
No issues with frozen jets here in the highlands despite sub-zero temperatures. No need for heated jets, and given they are mounted on the wiper arms I’m not sure how they would work.
As above proper washer fluid is all you need unless you’re in the arctic or something. |
15th Dec 2022 9:51am |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1422 |
I seem to have this problem also, mine are both switched to come on automatically in the Pivi Pro settings but when I start my car remotely they don't switch on until I unlock my car and actually get in. When the car is started remotely the Pivi screen remains off and none of the switchgear underneath the screen is lit up, it only 'boots' up when I unlock the car no matter how long the car has been running. Are other people seeing a different result if they start remotely? If I just jump in on a cold morning the front and rear screen both come on immediately. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Dec 2022 3:40pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3420 |
My one no longer puts the blowers on, my 90 went the same way. 24MY 90 D250 HSE, Tasman Blue
19th Dec 2022 4:52pm |
Mine definitely switches on the front windscreen when I remote start. Don’t know about the rear as that never freezes due to where I park it. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
19th Dec 2022 6:12pm |
Well, l don't have remote start but it's nice to have a vehicle where the locks don't freeze up in sub zero temperatures.
On my 2005 Defender l had to warm the door locks with a hairdryer before l could get in. |
19th Dec 2022 6:23pm |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 |
You do have remote start! You just don’t have the scheduled remote start. Pretty sure all new Defenders have it. Mine has it and yeah, only the blowers come on - not heated windscreen. https://instagram.com/bentheoandrews
19th Dec 2022 7:49pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
This is all interesting because I have a 2020 D240 First Edition and it has remote starting from the app where I can set how warm I want the car to try to warm to (never gets there within the 30 minutes preconditioning time). It always demises/defrosts both the front and rear screens and both wing mirrors.
I also have an all electric Mini……….. half the price of the Defender and in addition to defrosting ALL the windows and sunroof it has heated washer jet nozzles, mirrors and in preconditioning mode it heats the steering wheel and both front seats but not to as high a temperature as when I switch them on manually but at least the leather isn’t freezing cold to sit on and it does all of this in 22 minute and reduces my electric range by 2 miles if not plugged into a charger. There is no heated front screen in it but it uses a very efficient heat pump to blow warm air into the cabin and while the temperature is fixed it is set at 23C which is jolly toasty on a freezing morning. In 2011 I had an Evoque that had instant heating for the cabin as it used a PTC heater not scavenged heat from the engine bay just in those days there was no remote start to start it all off before you started the engine. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
20th Dec 2022 8:52am |
