Home > Puma (Tdci) > Dashboard Warning Lights
Thug
South Africa 2009 Defender 90 Puma 2.4 CSW Indus Silver
As I was pulling in to work this morning, the following dashboard lights came on. Handbrake / ABS & Traction Control.
It was raining most of the journey and I suspect that there is a faulty/loose connection somewhere.
Anyone have an idea where to start looking?
Post #974333 12th Dec 2022 9:56am
Thug
Went down and started the vehicle 10 minutes ago, dashboard lights have disappeared.
Obviously a wet connection, somewhere.
Post #974351 12th Dec 2022 12:04pm
Thug
Had a reoccurrence of the warning lights yesterday afternoon, so took the vehicle into the garage.
No warning lights this morning but the garage plugged in the diagnostic reader and reset the fault.
Said it could be the ABS pump on its way out.
5 minutes after leaving the garage, going round a bumpy corner, warning lights re-appeared.
I'm not really happy on taking a punt that it might be the ABS pump seeing that it's bloody expensive but at this point I think a second opinion is probably necessary.
Post #974561 13th Dec 2022 3:11pm
Martin
Site Admin
Could be a loose/failing wheel speed sensor?
What fault was the ABS module reporting?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974564 13th Dec 2022 3:17pm
Thug
Unfortunately, I didn't bother to ask, will see if I can find out tomorrow.
Post #974569 13th Dec 2022 4:13pm
Bluest
I've had this problem twice now, the first time it was the shuttle valve failure on the ABS pump, the second time it was a wheel speed sensor that had come out of the housing a bit. ON both occasion reading the ABS fault codes narrowed the problem down easily. 2007 110 TDCi Station Wagon XS
Post #974570 13th Dec 2022 4:51pm
Thug
Thanks for that info.
I have an obdlink lx reader that I’ll see if I can get code off tomorrow.
Post #974580 13th Dec 2022 7:13pm
Martin
Site Admin
You won't get a code with a generic OBD2 reader, the Wabco isn't OBD2 compliant.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974581 13th Dec 2022 7:35pm
Thug
Thanks.
Guess I’ll be visiting the garage again.
Post #974589 13th Dec 2022 8:57pm
GuJa
Germany 2008 Defender 90 Puma 2.4 SW Tonga Green
Well, I had nearly the same. It was a faulty sensor. I bought the cheapest I could get (25 €) and my garage got another 25 € for changing the front sensor. Problem solved (more than 50.000 km now). By the way the LR garage wanted more than 500 €!!!
Post #974852 16th Dec 2022 11:55am
Thug
I’m away at the moment, so haven’t had a chance to follow up.
I have though decided to order myself a Nanocom and the 15% Christmas discount will pay for the courier.
Once I receive it in the New Year, I’ll report back on the error codes.
Post #974888 16th Dec 2022 4:38pm
