Home > Td5 > TD5 battery spec
Rich1968
TD5 battery spec
Hi all
Does anyone know the battery spec for a TD5? No winch or other high power consuming ancillaries.
Question, is a 90ah 800A sufficient?
Rich
Post #973395 4th Dec 2022 5:53pm
geobloke
The standard battery is a 640 or a 664. Both of these are 105Ah. First is a 780CCA and the second a 680Ah.
Are you planning a dual batter setup in the future as this would be a good chance to do it.
Post #973400 4th Dec 2022 6:24pm
Rich1968
No dual set up needed.
Was hoping 90ah would be sufficient as £50 cheaper but will go for 105/110Ah.
Post #973403 4th Dec 2022 6:57pm
geobloke
No problem. The Ah are not as important as the CCA, if your 90Ah has decent CCA then you'd get away with that.
Post #973406 4th Dec 2022 7:13pm
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
Try Tayna, i went ofr a 900cca, varta fits fine
Post #976438 2nd Jan 2023 8:07pm
rsms
Slovenia
Time for a new battery in my 110 TD5.
I think a factory recommended battery is 110 Ah, CCA 800A.
Is Varta Silver Dynamic H3 (100 Ah, CCA 830A) a good choice? I would go for Varta Silver Dynamic I1 (110 Ah, CCA 920A), but I am afraid it wont fit as it is 393 mm long... Has anyone fitted a battery of this size?
Post #1015306 16th Nov 2023 10:55am
TexasRover
Battery size/spec is not as critical as say a tire size. They also deteriorate over time so what you are buying is reserve capacity above the bare minimum required to start the engine on a good day.
The bigger the battery the more reserve you have which means typically as the performance degrades over time it still works during say cold weather or for long cranking.
Some batteries are cheaper just because they are a common size and stocked in large volumes, it could be worth searching around a little to get the most bang for your buck.
Ultimately it needs to fit (also watch the height to avoid shorting out the positive terminal) and the terminals need to be on the correct location and of the correct size. Last time I had to buy a battery I just went to the wallmart with a tape measure and bought the cheapest biggest battery I could find.
Edit: Currently I have locked on to the Varta G14 battery 95Ah 850CCA 153x175x190, mainly because I have good experience with Varta and it fits my Disco 4 so I can keep a good old one spare for 2 cars (3 if I add the S3)
Post #1015311 16th Nov 2023 12:20pm
Jabberwocky
Luxembourg
I have 2 batteries under the passenger seat, can’t for the life of me remember what size the engine one is and my defender isn’t at home currently so I can’t take a look but it’s considerably smaller than standard but as long as the CCA is up to standard the actual capacity isn’t overly important.
Post #1015335 16th Nov 2023 3:16pm
Chicken Drumstick
Personally wouldn't bother with 2 batteries, don't really know why people go for 2. Almost everyone I've know with multiple batteries has had issues.
Just go for the biggest battery you can fit in the tray. Local agri place should have something suitable.
Post #1015336 16th Nov 2023 3:22pm
geobloke
Well I am not one of them. I have been running twin batteries in Defenders for a many years as I have had Defenders. No problems with it at all. The reason is simple. Back-up. When I am away from home I like to know that no matter what happens I have one dedicated battery for the engine. The other is simply for accessories, fridge and winch. All of which are not critical, but deserve their own power source. Keeping them separate also makes trouble shooting much easier as the two systems do not interact. It is not for everyone, but it is a tried and tested setup in my case.
Post #1015337 16th Nov 2023 3:32pm
Jabberwocky
Luxembourg
I have 2 because one is a leisure battery to power my camper.
Post #1015340 16th Nov 2023 3:43pm
4RF RDS
I have two of these under my seat (running a fridge often). H8 designation.
https://www.costco.ca/Energizer-H8-AGM-Bat...87650.html 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1015376 16th Nov 2023 9:05pm
Procta
Re: TD5 battery spec
Rich1968 wrote:
Hi all
Rich
i always go for the heavy duty variant of what's on, just for the extra starting power and insurance
and for what extra it costs Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #1015596 19th Nov 2023 2:47am
