![]() | Home > Td5 > TD5 battery spec |
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 84 ![]() ![]() |
Hi all
Does anyone know the battery spec for a TD5? No winch or other high power consuming ancillaries. Question, is a 90ah 800A sufficient? Cheers Rich |
The standard battery is a 640 or a 664. Both of these are 105Ah. First is a 780CCA and the second a 680Ah.
Are you planning a dual batter setup in the future as this would be a good chance to do it. |
No dual set up needed.
Was hoping 90ah would be sufficient as £50 cheaper but will go for 105/110Ah. Cheers |
No problem. The Ah are not as important as the CCA, if your 90Ah has decent CCA then you'd get away with that.
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 ![]() ![]() ![]() |
Try Tayna, i went ofr a 900cca, varta fits fine
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1121 ![]() ![]() ![]() |
Battery size/spec is not as critical as say a tire size. They also deteriorate over time so what you are buying is reserve capacity above the bare minimum required to start the engine on a good day.
The bigger the battery the more reserve you have which means typically as the performance degrades over time it still works during say cold weather or for long cranking. Some batteries are cheaper just because they are a common size and stocked in large volumes, it could be worth searching around a little to get the most bang for your buck. Ultimately it needs to fit (also watch the height to avoid shorting out the positive terminal) and the terminals need to be on the correct location and of the correct size. Last time I had to buy a battery I just went to the wallmart with a tape measure and bought the cheapest biggest battery I could find. Edit: Currently I have locked on to the Varta G14 battery 95Ah 850CCA 153x175x190, mainly because I have good experience with Varta and it fits my Disco 4 so I can keep a good old one spare for 2 cars (3 if I add the S3) |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 225 ![]() ![]() |
I have 2 batteries under the passenger seat, can’t for the life of me remember what size the engine one is and my defender isn’t at home currently so I can’t take a look but it’s considerably smaller than standard but as long as the CCA is up to standard the actual capacity isn’t overly important.
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 785 ![]() ![]() |
Personally wouldn't bother with 2 batteries, don't really know why people go for 2. Almost everyone I've know with multiple batteries has had issues.
Just go for the biggest battery you can fit in the tray. Local agri place should have something suitable. |
Well I am not one of them. I have been running twin batteries in Defenders for a many years as I have had Defenders. No problems with it at all. The reason is simple. Back-up. When I am away from home I like to know that no matter what happens I have one dedicated battery for the engine. The other is simply for accessories, fridge and winch. All of which are not critical, but deserve their own power source. Keeping them separate also makes trouble shooting much easier as the two systems do not interact. It is not for everyone, but it is a tried and tested setup in my case.
I have 2 because one is a leisure battery to power my camper. |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 956 ![]() ![]() ![]() |
I have two of these under my seat (running a fridge often). H8 designation.
https://www.costco.ca/Energizer-H8-AGM-Bat...87650.html 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5224 ![]() ![]() |
i always go for the heavy duty variant of what's on, just for the extra starting power and insurance and for what extra it costs ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
