![]() | Home > Td5 > Need front door lock barrels that match factory locks |
The only way is to replace the damaged barrels with matching ones, unfortunately, which as far as I'm aware can only be ordered through LR.
Changing the ignition barrel isn't too bad if you go in prepared with a new bracket and bolts so that you can hack the old one off. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1232 ![]() ![]() ![]() |
You can buy a lock set, 2 doors and ignition barrel with two matching keys for about 130, cheaper if you want the cheap looking keys. You obviously need to fit there items, but they at least be new. I am planning to do this as my doors open with about any key. Look at LRParts, but you can probably get at many places
