Home > Puma (Tdci) > Best 2-stroke?
Page 2 of 2 <12
MK
if you use 2T (2-stroke) oil then you need to change the engine oil more often..... Puma 110" SW
Post #93273 8th Oct 2011 1:15pm
spudfan
Ireland
FC for the Puma owing to the catalytic converter.Castrol Actevo seems most suited as it is mineral based and up to FC spec. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #93274 8th Oct 2011 1:16pm
ZeDefender
MK wrote:
if you use 2T oil then you need to change the engine oil more often.....
Aahh - I think you mean if you add 2SO in general? How much more often for the engine oil changes?
Cheers,
Matt Tell someone you love them today because life is short.
Post #93275 8th Oct 2011 1:18pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Use TCW-3 mineral marine two stroke.It's low ash and burns at lower temp.The mineral oils mix and become one with diesel with no separation.If you can't get mineral use semi-synth. Puma 110 SW
90 V8 SOFT TOP
Post #93277 8th Oct 2011 1:28pm
MK
Cheers,
Matt
Based on 2 analyses on 913C, not more than 7kkm Puma 110" SW
Post #93303 8th Oct 2011 5:15pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
For which reason engine oil must be replaced with shorter frequency ?
Post #93340 9th Oct 2011 5:06am
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
I use the Actevo too.
According to the German bloke who started the whole 2so debate over on another forum, the optimum ratio to add to the diesel is 1:200.
On a 110 this equates to approx. 330ml. I measured this amount out (using water) in a screw top clear plastic drinks bottle, marked the level, dried out the bottle, and now keep one 'dose' measured out and ready each time.
BTW, Halfrauds charge £8.99 for a 1litre bottle. Nielsen CDG (google it) charge £4.85, or £4.55 if you order 16 or more! About to see if Opie can match that! :-)
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #93346 9th Oct 2011 7:43am
szracer
Correction - Nielsen's £4.85 price is for 12 or more. I buy in bulk! Extra 30p off comes if you buy 16 or over.
Otherwise it's £5.99.
2005 Ducati ST3
1954 Sunbeam S8
Post #93348 9th Oct 2011 7:47am
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
BTW, Halfrauds charge £8.99 for a 1litre bottle. Nielsen CDG (google it) charge £4.85, or £4.55 if you order 16 or more! About to see if Opie can match that! Smile
did you see if opie could do better than nielsen could do on 12 bottles ?
Post #103494 30th Nov 2011 10:49am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I've used some Castrol 2stroke oil, JasoFB ... 250ml/70L fuel ... 2l toal, 8 diesel tanks
It's quieter, I think, but my L/km (Mpg) is the same ... I'll keep using it! Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #103506 30th Nov 2011 11:43am
Page 2 of 2 <12
