Home > Maintenance & Modifications > What’s in your in-car toolbox?
Page 2 of 2 <12
landy andy
I’ve seen many a thing forked up, on a LR, and that who the tools are normally for.
Post #969214 28th Oct 2022 7:18pm
sako243
Um where do I start.
Theres the Milwaukee power tools: big impact, little impact, driver, ratchet, jigsaw, plane, table saw, chop saw, drill, sander and grinder.
Then there's the sockets, torque wrenches, screwdrivers, chisels, router, timing kits, brake caliper rewind tool, bearing pullers, punches, hammers, pry bars and chainsaws.
Oh and let's not forget the electrical side of things, soldering irons, quad channel oscilloscope, precision multimeter, wires, power supplies and laptop.
Oh but then my Land Rover is a multi purpose work vehicle spanning mechanics, electronics, carpentry and metal working. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #969229 28th Oct 2022 9:17pm
Dave12345
United Kingdom 1989 Defender 90 300 Tdi PU Keswick Green
Hope your security is good! That’s an immense rolling workshop by the sounds of things
Post #969230 28th Oct 2022 9:18pm
sako243
Security is west Wales and usually two labs in transit.
Perks of living out in the sticks. Ed
Post #969238 28th Oct 2022 10:18pm
Another essential which I don't travel without in any vehicle is a hi-vis coat. With the modern standard of driving I reckon you'd have to be barking not to carry hi-vis.
Post #969240 28th Oct 2022 11:23pm
Dave12345
Good shout Blackwolf I’d thought of that then forgotten.
That helps Sako - i’m so much more relaxed when I’m back on Anglesey than I am in Merseyside with it, it must be said, although I’m not sure if thats a false sense of security.
Post #969287 29th Oct 2022 1:22pm
Jabberwocky
Luxembourg
Mobile phone
AA membership
Job done.
Post #969468 30th Oct 2022 6:13pm
MichaelE
Three years ago or so I was leaving a Billing event. I'd only driven a few yards off my camping spot and the 200Tdi in my 110 cut out dead and wouldn't restart. It was absolutely peeing it down and I sat there for a good few minutes contemplating. Mulling things over I had an idea that it was the fuel injector pump cutoff. I had the bonnet up and could see the cable was still attached but couldn't reach it [I'm 5ft 7 which is normally good enough for most jobs but not reaching in to this engine bay].
So I got the Seeley fold up step thing that hooks over the wheel that I had just bought from that very show. That got me up there and now it goes everywhere with me.
Once I had access, I gave the cutoff cable connector a wiggle and tried the starter. The engine fired up and I was on my way. I got to thinking that I was lucky, but what if it hadn't just been a bad connection but a broken connector or an electrical failure somewhere in the harness? So now I carry in both my 200Tdi and 300Tdi a length of cable with a spade terminal at one end and a crocodile clip at the other, long enough to stretch from the fuel injector pump to the battery.
Post #969510 31st Oct 2022 12:51am
Lightwater
Australia
Don't think it has been mentioned yet.
Toilet paper.
DC clamp meter.
Builders gloves.
Moisture trap, after cooler (which can be refrigerated), air tank.
Someone to clean the car with triple ARB compressors.
& water cleaning.
 Visitor - Freelander owner
Post #969531 31st Oct 2022 11:31am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Jabberwocky wrote:
Mobile phone
AA membership
Job done.
And some good hiking shoes, 6 days worth of food and water too Very Happy
Post #969580 31st Oct 2022 8:40pm
markb110
I’m starting to think that you need to buy a trailer…… Whistle
Post #969594 31st Oct 2022 11:19pm
Lightwater
Australia
The Bosch 10.8/12v angle grinder is brilliant. It can't do a marathon. But it can do the first cut quickly.
60mm od steel pipe 3.0mm wall thickness. First cut 2 minutes. Second cut 4 minutes. Third cut 7 minutes.
But that first cut is impressive & it's a lot quieter than the larger angle grinders. Good to get into tight corners.
If all else fails:
Post #969597 1st Nov 2022 3:52am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I have a fully equipped workshop at home and there's no way all that will fit in the back of the Defender. Therefore I think about what I could fix at the side of the road and the little things that can go wrong stopping progress.
Every time we've failed to proceed, it's been an electrical fault. Therefore I carry some spare cable, connectors and the matching tools including a multimeter.. Along with fuses, relays, cable ties and duck tape.
Given that it's a Defender I also carry recovery kit. Maxtrax, soft shackles, straps, shovel, ratchet straps and high lift jack.
If there's a major mechanical failure, mobile phone and AA membership.
Post #969618 1st Nov 2022 9:47am
Page 2 of 2 <12
