- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Gasket
clutch height adjustment - rubber mats | |
Hi folks. I've just fitted a wright off road mat to the Puma defender (2010, 2.4) and noticed that the clutch pedal is hitting the mat when fully depressed.
Before fitting I had checked the pedal height to make sure it was at factory settings and was all correct (140mm from bare floor plate to base of bare pedal).
The brake and throttle pedals are obviously miles clear of the mat - its just the clutch.
So, is it just a case of adjusting the pedal to raise the lower stop a little to ensure it clears the mat?
27th Oct 2022 2:31pm |
