Home > In Car Electronics > Replacing cigarette socket - plug shape
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Hi all,
I have bought one of these:
https://www.fruugo.co.uk/modified-car-char...gJrl_D_BwE
With the intention of replacing the cigarette socket.
However, the new charger has two parallel spade pins, while the defender has a type 1 alternator plug (T shaped pins).
I really don’t want to mess with the wiring and I guess having the T shaped pins is to prevent plugging in the wrong way round.
Ideally, I would like to attach a male version of the type 1 plug to the charger and then simply plug into the existing wiring.
However, I can’t seem to find a male version of the type 1 plug anywhere.
Does anyone have any suggestions? 2011 CSW XS 90
Post #968026 17th Oct 2022 1:45pm
hank
Post #968028 17th Oct 2022 1:49pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
If you really don't want to cut any wires, then can't you just make up a very short loom to fit into the existing harness, but provide the plugs that you need on your new socket?
Post #968029 17th Oct 2022 1:49pm
Isn't the T shaped plug just two standard female blade connectors inside? If so, release them from the plug and just plug them in. You may need an insulated sleeve for the positive, or some heat shrink. Darren
Post #968030 17th Oct 2022 1:50pm
^ Yes, it is. You can simply release the contacts from the shell and fit them into another suitable shell, or insulate them individually with heat-shrink.
Post #968041 17th Oct 2022 2:52pm
rustandoil
That's a interesting USB outlet.... Be interesting to see how it fits in the dash, won't be for me if you have to open the hole out Confused
Post #968057 17th Oct 2022 4:29pm
Martin
Site Admin
No, it has two latching terminals inside.
T shaped sockets are available (I use them on the "T" looms to piggy back from the lighter plug).
I normally use the same plug as factory, with latching terminals; but in this case 2x shrouded female spades would be fine.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #968061 17th Oct 2022 4:52pm
SJM2018
Thank you for the replies!
Found what I hope is a matching t-block thing.
Will share some pictures once fitted 2011 CSW XS 90
Post #968140 18th Oct 2022 10:59am
hank
hank wrote:
https://www.ebay.co.uk/itm/263523160234
T connector available here
As per my post above the connector is available from ebay via the link provided. I know this to be the correct connector as I purchased this very item personally to achieve exactly as you intend to do
[/img] > 110 XS Double Cab
Post #968188 18th Oct 2022 2:54pm
rustandoil
Thanks for that link.... I'm going to get one of these so that I can take a accessory live to a relay without chopping wires
Post #968195 18th Oct 2022 3:43pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Re: Replacing cigarette socket - plug shape
SJM2018 wrote:
https://www.fruugo.co.uk/modified-car-charger-usb-c-socket-outlet-qc30-pd-fast-charging-12v24v-with-switch-for-boat-automobiles-motorcycle-ship/p-84151939-173544925?language=en&ac=croud&gclid=EAIaIQobChMI35DWs7Hn-gIVM-7mCh1Euw6-EAQYBiABEgJrl_D_BwE
If you want the same functionality and a built-in voltmeter for less cost: https://www.ebay.co.uk/itm/354304543425
Post #968276 19th Oct 2022 9:43am
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
@Intercept
Thanks, this is really useful. It's one of those things that I did not know I needed until I saw your post. Very Happy
Post #968413 20th Oct 2022 10:29am
SJM2018
I choose that one because I’m a tart and wanted it to be green like the rest of the buttons / gauges Laughing 2011 CSW XS 90
Post #968451 20th Oct 2022 3:20pm
Oldowner
I have turned down various USB sockets to fit the Puma dash using my myford lathe. Usually need a mm or so turned off so they fit correctly to the Puma dash, and looks OEM.
Post #968472 20th Oct 2022 6:17pm
rustandoil
That's good, I'll happily turn down the socket rather than butcher my dash 👍🏻
Post #968484 20th Oct 2022 8:31pm
