Home > Technical > One shot grease in earlier swivel housing with Railko bush
Page 2 of 2 <12
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
I always opt for EP90. my thinking is that any swivel ball and seal in decent condition can contain the oil quite cleanly (I have one swivel that does). But mainly, due to years of experience off-roading and deep water wading, I do like to be able to drain the oils from all locations so I can replace with clean (dry) oil. How are you supposed to drain the swivels after water ingress if you have OSG?
Post #966707 4th Oct 2022 9:29pm
Dinnu
Good point OSkool. That was my concern when I got stuck in a deep hole filled with water for an hour or so until I was recovered. But the newer swivels do not have drain plugs! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #966714 5th Oct 2022 4:22am
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
You would be lucky to find any LR running anything other than OSG in the swivels, I remember running 1000 grade heavy oil in my series swivels because even when they are in perfect condition they will eventually leak, even Toyota and Nissan owners in OZ use LR OSG because of leaks, it's a road worthy failure if there is leaking from them.
Post #966960 6th Oct 2022 11:34pm
Dinnu
Was thinking... if using EP90 so that any water that leaks in can drain out... then surely oil is also coming out if the water can go in. Or the difference in viscosities can allow the water to leak in but not the oil to leak out?
Any one use EP140?
One shot grease is molybdenum grease? better lubricating properties compared to EP oils? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #966971 7th Oct 2022 7:06am
I Like Old Skool
To get the water out of the swivels you do an oil change, like changing the engine oil. Drain out the dirty oil with contamination then refill with fresh oil. You can't do that with OSG, so presumably just leave the water and grease festering in there until something fails (CV joint or swivel bearings)?
Post #966973 7th Oct 2022 7:54am
Page 2 of 2 <12
