Home > Td5 > TD5 intermittent non start
freddie206
United Kingdom 2006 Defender 110 Td5 HT Belize Green
2006 TD5 no previous starting issues.
Stopped at the shops on the way home yesterday and when I went to start up it was having none of it.
When I turned on the ignition I was only getting the oil pressure, battery and handbrake warning lights and not the engine management and glow plug lights. The fuel pump also wasn't running. I checked the fuel pump fuse which was fine. After scratching my head for a bit I thought I'd give it another go and it fired up straight away after all the correct dash lights illuminated.
Any suggestions as to where I should start my search? An intermittent fault is definitely one of the most frustrating!
Post #965988 26th Sep 2022 7:27am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Take a look at the fuel pump relay (under the seat, the one on the right as you look at them through the door) and the socket it sits in. A bad contact here is a potential cause for poor starting.
Post #965993 26th Sep 2022 9:16am
rallysteve
Likewise the main relay which is next to it.
Post #965994 26th Sep 2022 9:37am
freddie206
Thank you both for the suggestions. I’ll take a look into those.
Im leaning more towards a fuel pump issue because I always get power when switching on the ignition and the engine will turn over.
Post #966003 26th Sep 2022 11:46am
rallysteve
You mention you didnt get the engine managenent/glow light when it wouldnt start. The main relay powers the ECU and the ECU controls the fuel pump relay.
Also worth checking the ECU earths as they are prone to cause issues
Post #966004 26th Sep 2022 11:54am
4RF RDS
Starter solenoid contacts wear out and require a rebuild. If it happens again and the other suggested fixes don’t cure it. Look into that Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #966098 27th Sep 2022 5:54pm
freddie206
The engine always turns over so I’m not sure it’s a starter motor issue but I will bare that in mind for future reference.
I have just added a Rev counter which obviously meant tapping into the instrument loom. Perhaps I should take another look at my splices. Would a faulty connection on an earth there have knock on effects?
Post #966115 27th Sep 2022 7:36pm
4RF RDS
Well defo not starter solenoid then Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #966119 27th Sep 2022 7:40pm
cocker
Had this problem and it was the relays under the driver’s seat bad contact cleaned up and cable tie did the trick
Post #966146 28th Sep 2022 7:02am
freddie206
So the main relay powers the ecu which in turn powers the fuel pump and glow plug relays?
Post #966150 28th Sep 2022 8:17am
Screbble
Yes that’s correct I think.
There is an inertia switch in line with the main relay - brown cable to the main relay coil (86) and the orange/brown cable from the main relay normally open contact (87) feeds the relay coils (86) of both the glow plug relay and fuel pump relay.
Hope that helps.
Post #966193 28th Sep 2022 6:56pm
geobloke
Just thought I would weigh in here, this all sounds very familiar to Miffy and I Rolling Eyes
I would urge you to check the internal contacts of your relays, page 13, last post of the Miffy thread shows how pitted they can become. This was a cause of my intermittent starting.
https://www.defender2.net/forum/topic53859-180.html
Post #966204 28th Sep 2022 7:58pm
freddie206
Thanks to all who contributed ideas.
I checked the relays under the drivers seat and they both looked clean but since then I haven’t had any issues so perhaps a good wiggle was just what they needed!
Onto a new problem now…
Post #967678 14th Oct 2022 4:55pm
rallysteve
Excellent, if that is the case it is worth trying to close up the crimp terminals in the relay holders so they are a tighter fit onto the relay terminals Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #967679 14th Oct 2022 4:58pm
Dtes
1984 Defender 90 Td5 HT Firenze Red
Next time it happens give the main relay another wriggle, odd’s are it’s that.
The ecu earth wire and inertia switch can also case the same problem
Post #967831 16th Oct 2022 11:14am
