![]() | Home > Td5 > TD5 intermittent non start |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 334 ![]() ![]() ![]() |
Take a look at the fuel pump relay (under the seat, the one on the right as you look at them through the door) and the socket it sits in. A bad contact here is a potential cause for poor starting.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Likewise the main relay which is next to it.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 90 ![]() ![]() ![]() |
Thank you both for the suggestions. I’ll take a look into those.
Im leaning more towards a fuel pump issue because I always get power when switching on the ignition and the engine will turn over. |
You mention you didnt get the engine managenent/glow light when it wouldnt start. The main relay powers the ECU and the ECU controls the fuel pump relay.
Also worth checking the ECU earths as they are prone to cause issues Steve 02' 110 TD5 Double Cab Rebuild Thread |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
Starter solenoid contacts wear out and require a rebuild. If it happens again and the other suggested fixes don’t cure it. Look into that
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
The engine always turns over so I’m not sure it’s a starter motor issue but I will bare that in mind for future reference.
I have just added a Rev counter which obviously meant tapping into the instrument loom. Perhaps I should take another look at my splices. Would a faulty connection on an earth there have knock on effects? |
Well defo not starter solenoid then
cocker Member Since: 23 Sep 2021 Location: Merseyside Posts: 38 ![]() ![]() |
Had this problem and it was the relays under the driver’s seat bad contact cleaned up and cable tie did the trick
So the main relay powers the ecu which in turn powers the fuel pump and glow plug relays?
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Yes that’s correct I think.
There is an inertia switch in line with the main relay - brown cable to the main relay coil (86) and the orange/brown cable from the main relay normally open contact (87) feeds the relay coils (86) of both the glow plug relay and fuel pump relay. Hope that helps. |
Just thought I would weigh in here, this all sounds very familiar to Miffy and I
![]() I would urge you to check the internal contacts of your relays, page 13, last post of the Miffy thread shows how pitted they can become. This was a cause of my intermittent starting. https://www.defender2.net/forum/topic53859-180.html |
Thanks to all who contributed ideas.
I checked the relays under the drivers seat and they both looked clean but since then I haven’t had any issues so perhaps a good wiggle was just what they needed! Onto a new problem now… |
Excellent, if that is the case it is worth trying to close up the crimp terminals in the relay holders so they are a tighter fit onto the relay terminals
Dtes Member Since: 01 May 2022 Location: Staffordshire Posts: 10 ![]() ![]() |
Next time it happens give the main relay another wriggle, odd’s are it’s that.
The ecu earth wire and inertia switch can also case the same problem |
