![]() | Home > Tdi > Oil leak |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
Looks like rocker cover and or oil drain pipe, change both, may as well do a valve set while your there.
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 972 ![]() ![]() |
Found the culprit. Split in the breather hose the connect to the rocker cover.
A set of silicone replacement hoses on the way ![]() |
