Home > Technical > Door stricker location on panel
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
Hi
Does anyone happen to have the striker location as mine have been totally torn off and have bent the panel so I think my measurements will be a bit off, and I want to drill the holes in the right place on the replacement pieces.
Post #965285 17th Sep 2022 11:19am
Screbble
Is this for the front and is it the same as a 90?
If yes to both I’ll pop out and measure Thumbs Up
Post #965306 17th Sep 2022 5:26pm
Screbble
Near side 90:
Post #965307 17th Sep 2022 5:36pm
Sam smith
That is great thank you is the striker bit actually straight as the bolts on the broken bit that cam off don’t seem to be quite in line but this may just be from it getting bent.
Post #965328 17th Sep 2022 7:47pm
Screbble
The bolts are in line vertically if that’s what you mean?
The striker itself is perpendicular to the door jamb (if that’s the right word!).
I may be stating the obvious, but the holes are larger than the diameter of the bolt, and there’s a striker plate with captive nuts behind, so you can adjust.
Hope that helps 👍
Post #965330 17th Sep 2022 8:01pm
Sam smith
Yes thank you I will have to compare the measurements tomorrow to see what I get. I don’t reckon the strikers on mine were put on square then as they were definitely wonky on the “b” post where the striker mounts as the rubberised coating mark makes it look like they weren’t square at all.
Is there any possibility at all that you could measure from the seam under the seal to the centre of each of the bolts for me as that is a easier reference point on the replacement panels I have. No worries though if it’s too much of a pain.
Post #965334 17th Sep 2022 8:35pm
Screbble
No problem I’ll do that tomorrow 👍
Post #965337 17th Sep 2022 9:28pm
Screbble
Hope this is what you meant?
It’s 47mm from the outside face of the seam to the centre of the bolt on the top fixing, and 45mm on the bottom fixing.
I used a straight edge on the seam to measure but need 3 hands if I were to take a photo with that in the picture!
Post #965353 18th Sep 2022 7:21am
Sam smith
Legend, thank you I really appreciate it!
So they are ever so slightly not straight then
Post #965361 18th Sep 2022 7:48am
Screbble
No problem - it gave me an excuse to have a poke around the general area with my small paintbrush and ACF50 Shocked
Yes it’s a ‘bit out’ but WELL WITHIN the legendary tolerances of a Defender Rolling with laughter
I recall that the holes in the panel are larger than the bolt (set screw) diameter, to allow adjustment, as there’s a backing plate with captive nuts.
It might be better if someone on the forum can measure a panel that hasn’t got the striker plate attached as you’ll want to do it once and do it right - unlike LR…
Good luck 🤞
Post #965365 18th Sep 2022 8:19am
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
There is easily enough play for the holes to be dead straight. There's quite a bit of adjustment due to the size of the holes on mine (about 5mm from one extreme to the other side to side and up and down)
Post #965473 19th Sep 2022 9:57pm
