Home > In Car Electronics > Hard wire Dashcam |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3369 |
I used one of these for my nextbase dashcam on the TD5, pinched the stereo fuse position as I haven't got one Its not always on though as is linked to the ignition. The onboard battery in the camera powers the parking mode so it doesn't need to be wired up to an 'always on' fuse.
12th Sep 2022 3:01pm |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 177 |
I connected mine to the permanent feed for the interior light and fitted camera by the rear view mirror.
12th Sep 2022 3:58pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
Scott, I've used the same kit with my Nextbase for 4-5 years without issue.
Can't rememeber which fuse I piggybacked but from memory it will be one I dont/barely use. Something like the rear heated screen. I'll check later. I managed to route mine from the fuse board under the dash, up the A pillar (behind the cover) and then superglued in place in the run across the screen rubber/headlining edge. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
13th Sep 2022 12:24pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3747 |
Rosco
Great if you can let me know that would be great. I'm used to getting cables around having fitted the rear camera. I do try and hide them best I can |
13th Sep 2022 12:35pm |
GM_FFX Member Since: 15 Sep 2021 Location: Washington DC Posts: 31 |
What size tap-a-fuse is needed? I guess it would be the "standard" size not mini, not micro right?
1st Mar 2023 1:06am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1072 |
Yes, they're all of the old "standard" size Compatible with 6.3mm spades (edit: sorry, that's about 1/4 inch in your world ).
1st Mar 2023 3:11pm |
thank you!
2nd Mar 2023 4:51pm |
