Home > In Car Electronics > Hard wire Dashcam
Stacey007
Hard wire Dashcam
Hello
I would like to wire my dashcam in so always on (as it has a Parking mode) Its a Nextbase 622GW
I have seen these kits?
My question(s)
1) Is this ok to use a Piggy back fuse... What do I chose in the fuse box to 'tap' into.
2) Does the back just go to Earth
Thanks
Post #964755 12th Sep 2022 2:56pm
camelman
I used one of these for my nextbase dashcam on the TD5, pinched the stereo fuse position as I haven't got one Smile Its not always on though as is linked to the ignition. The onboard battery in the camera powers the parking mode so it doesn't need to be wired up to an 'always on' fuse.
Post #964757 12th Sep 2022 3:01pm
ak615
I connected mine to the permanent feed for the interior light and fitted camera by the rear view mirror.
Post #964767 12th Sep 2022 3:58pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Scott, I've used the same kit with my Nextbase for 4-5 years without issue.
Can't rememeber which fuse I piggybacked but from memory it will be one I dont/barely use. Something like the rear heated screen. I'll check later.
I managed to route mine from the fuse board under the dash, up the A pillar (behind the cover) and then superglued in place in the run across the screen rubber/headlining edge. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #964863 13th Sep 2022 12:24pm
Stacey007
Rosco
Great Smile if you can let me know that would be great.
I'm used to getting cables around having fitted the rear camera. I do try and hide them best I can Smile
Post #964867 13th Sep 2022 12:35pm
GM_FFX
United States 1992 Defender 90 200 Tdi HT Rimini Red
What size tap-a-fuse is needed? I guess it would be the "standard" size not mini, not micro right?
Post #984018 1st Mar 2023 1:06am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Yes, they're all of the old "standard" size Smile Compatible with 6.3mm spades (edit: sorry, that's about 1/4 inch in your world Wink).
Post #984067 1st Mar 2023 3:11pm
GM_FFX
thank you!
Post #984203 2nd Mar 2023 4:51pm
