Home > Technical > Diagnostic Plug Location
Jhollow
Canada
This may be a dumb question but I assume a 2006 has a diagnostic plug (ODP?) somewhere but I cannot find it. The owners manual isn't much help. Where should I be looking?
Thanks.
Post #963704 1st Sep 2022 6:55pm
Ianh
I’m assuming you have a TD5, if so I believe the OBD port is Under the cubby box / middle seat at the side of one of the front seats . https://www.outilsobdfacile.com/location-p...fender-1-2.
It could also be under the plate beneath the cubby/ middle seat or been cut off as an anti theft measure.
Note prior to the Puma which has an OBD2 (OBDII) port I.e the TD5, the OBD port is proprietary and a standard OBD2 scanner won’t work correctly. See https://www.defender2.net/forum/topic84428.html?highlight=obd2
Post #963707 1st Sep 2022 7:20pm
landy andy
As said. Under mid seat, or cubby box on a Td5. But we do hide them, and only certain readers read them.
Post #963720 1st Sep 2022 8:03pm
Jhollow
Canada
Many thanks. I will see if I can locate it tomorrow. Being a late 2006 (September) is it possible that it could have the OBD2? Hoping a PO hasn't cut it off.
Post #963725 1st Sep 2022 8:39pm
Ianh
Unfortunately only 2007 onwards 2.4 and 2.2 puma defenders have a OBD2 compliant port, located in the fuse box in the drivers footwell on a RHD vehicle.
Post #963727 1st Sep 2022 8:44pm
