Home > Technical > Diagnostic Plug Location |
Jhollow Member Since: 27 Apr 2022 Location: Ontario Posts: 83 |
This may be a dumb question but I assume a 2006 has a diagnostic plug (ODP?) somewhere but I cannot find it. The owners manual isn't much help. Where should I be looking?
Thanks. |
1st Sep 2022 6:55pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1999 |
I’m assuming you have a TD5, if so I believe the OBD port is Under the cubby box / middle seat at the side of one of the front seats . https://www.outilsobdfacile.com/location-p...fender-1-2.
It could also be under the plate beneath the cubby/ middle seat or been cut off as an anti theft measure. Note prior to the Puma which has an OBD2 (OBDII) port I.e the TD5, the OBD port is proprietary and a standard OBD2 scanner won’t work correctly. See https://www.defender2.net/forum/topic84428.html?highlight=obd2 |
1st Sep 2022 7:20pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5698 |
As said. Under mid seat, or cubby box on a Td5. But we do hide them, and only certain readers read them.
1st Sep 2022 8:03pm |
Many thanks. I will see if I can locate it tomorrow. Being a late 2006 (September) is it possible that it could have the OBD2? Hoping a PO hasn't cut it off.
1st Sep 2022 8:39pm |
