Home > Puma (Tdci) > Separating disc from hub
olivers
2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Replacing (edit: rear) brake discs on my 130. Got the hub off, turn it over, remove five bolts holding the brake disc in place… and then… it doesn’t move a bit. Attempts to persuade it unsuccessful so far, gave up for the evening before I’m tempted to whack it too hard… checked Haynes, it says “slacken and remove the bolts securing the disc to the hub assembly, and separate the two”. Well then.
Is there a magic trick to make the two pop apart without doing damage?
Post #963431 30th Aug 2022 8:25pm
Retroanaconda
If you’re replacing the disc then just use a hammer to shock them off the hub.
Cleaning around the join and applying some penetrating oil may help.
Post #963433 30th Aug 2022 8:31pm
olivers
Excellent, thanks. That was my thought, but then I thought I’d better be at least a bit careful Wink
Post #963434 30th Aug 2022 8:36pm
htb2
Wales
If your discs are getting a bit thin, its easy to snap disc off the bell.ie snap the disc into two pieces
Post #963437 30th Aug 2022 8:51pm
olivers
I don’t think the disc is thin enough for that. I’m replacing it because it has disintegrated in a strange way, perhaps because the pad was gone.
Post #963438 30th Aug 2022 8:54pm
Retroanaconda
I’ve had that before on mine, caused by salt corrosion. I’ve also snapped a disc off while trying to remove as above.
You shouldn’t have to hit it too hard unless it’s really seized on there. Work around it gradually as you start to see it separate as it needs to come off more or less straight.
Post #963439 30th Aug 2022 8:56pm
olivers
I’ll get on it tomorrow. Sure it’ll come off - was just wondering if I missed something. I changed a couple discs before, but it’s been a few years and as far as I remember they came off without a hitch.
Thanks for your comments!
Post #963441 30th Aug 2022 8:59pm
kenzle8a
Large rubber mallet, if that doesn’t work, sledge hammer.
It’s a Defender, not a delicate swiss watch…
Post #963442 30th Aug 2022 9:18pm
jst
Copper hammer, hold hub in vice and hit disc. Or hold disc. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #963453 30th Aug 2022 11:50pm
MadTom
On a bit older TD5 130 i was using hydraulic press. Brake discs were worn, but not the hub. It took 5t of force to remove the old disk. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #963464 31st Aug 2022 6:44am
olivers
Alright, that’s sorted now - I held the hub in a vice and whacked the brake disc quite a while with a lump hammer before it came off, but eventually it did. Thanks everybody for confirming I wasn’t on the wrong track!
Post #963564 31st Aug 2022 6:18pm
