![]() | Home > Off Topic > Any landscape gardeners out there? |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 760 ![]() |
![]() Click image to enlarge There are a few products out there but I always use Easy Joint. Make sure the joints are clean then soak the patio with water and keep it wet. I tip the contents of the bag into the tub then full with water until it’s covered with about an inch of water. Fill grouts with a large trowel, run a pointing iron over it then brush off the excess with a soft brush. Good luck🙂 |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 ![]() ![]() |
Cheers. Thanks for the tip on keeping it wet.
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
I use the same stuff as gcc130, use it the same as he described, really good product
Thanks both, worked a treat.
