Home > Off Topic > Any landscape gardeners out there?
ChrisDefender
Hoping to pick on the wealth of knowledge as I am a basic DIY'er.
Has anyone got the best solution/material for re-pointing a patio please? I've scraped it all out so its nice and clean, gaps are about 25mm deep and 15mm wide. I used Geo-Fix last time which was great and has lasted about 7 years with numerous jet washes.
Just wondered if threes abetter solution or whether good old cement is the best option.
Not got the skills or confidence to do the flow stuff.
Many thanks.
Post #961514 13th Aug 2022 10:32am
gcc130
There are a few products out there but I always use Easy Joint.
Make sure the joints are clean then soak the patio with water and keep it wet. I tip the contents of the bag into the tub then full with water until it’s covered with about an inch of water. Fill grouts with a large trowel, run a pointing iron over it then brush off the excess with a soft brush.
Good luck🙂
Post #961526 13th Aug 2022 12:50pm
ChrisDefender
Cheers. Thanks for the tip on keeping it wet. Thumbs Up
Post #961529 13th Aug 2022 2:18pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
I use the same stuff as gcc130, use it the same as he described, really good product Thumbs Up Cogito ergo sum
Post #961547 13th Aug 2022 4:24pm
ChrisDefender
Thanks both, worked a treat.
Post #961831 16th Aug 2022 8:03am
