Home > In Car Electronics > Central locking / electrical fault
Poulstonb
Evening all I have a 2003 90 xs station wagon
Working my way through some issues on my newly acquired defender .
When I bought privately I was told the central locking had been disconnected due to a electrical fault .
I’ve managed to speak to the previous garage who maintained it and they stated the green box behind the instrument cluster which houses the relay was changed to one that didn’t support central locking as original was faulty and that’s all they had .
They said I need to buy a kit from eBay called a 10AS, which is a relay that gets soldered onto the board . I’ve had an auto electrican do this but still no central locking .
I’m taking it apart he’s found several unknowns , can anybody firstly help with my central locking dilemma and secondly identify anything in photos.
What’s the silver box do ?
What’s the cut orange wire from?
Is this ok , seems to be a joint going to door.
Lastly does anybody have a wiring diagram for my vehicle
Regards ben
Post #960217 1st Aug 2022 4:12pm
Gasket
Can't help with the wiring mod but re: the 10AS thing just look to a company like technozen.
https://www.technozen-electronics.co.uk/la...-services/
Basically the base 10AS ECU spec did not come with the relays necessary to power the central locking. You remove your ECU post to Paul at Technozen and he'll add them back in to the spec that yours should be. I'm about to do this on mine as I'm retrofitting factory CL.
As your ECU isn't the original it might be worth Paul checking that all the alarm/immobiliser bits are activated too. Pretty painless and only costs about £50.
Give him a call, he's a nice lad.
EDIT: see you've already had an electrician have a go. Might be worth calling Paul in case there's something else that needs switched on. Failing that its out with the test lamp to find the fault.
I can't see a green 10AS in your pics unless I'm missing something.
Orange and pink wires control the CL actuators - someone more knowledgeable will be along shortly but the cut orange wire might be your issue.
Post #960220 1st Aug 2022 4:22pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
The nasty blue and red repair is for electric windows, they break for a past time.
The wires going to the CDL motors in the door are pink and yellow and will lead directly to the 10AS box behind the dash.
If you google 'Land Rover Defender Td5 2002 wiring diagram' you will find several results linking you to a PDF version
The silver box could be some sort of power boost chip thingy? A tracker maybe? Does it say anything on it? Where do the wires go?
Post #960221 1st Aug 2022 4:28pm
Poulstonb
The silver box has no writing on it , a power chip is possible as the car does seem to have more power than others I’ve previously driven.
It has 3 wires one goes to ground one to the what I think is ecu and other I can’t trace.
Post #960224 1st Aug 2022 4:34pm
Retroanaconda
I’m pretty sure that the 10AS has to be programmed to enable central locking, just adding the relays to the board is not enough. If the one in yours came from a base spec vehicle without central locking then the function will not be turned on in the software.
Post #960235 1st Aug 2022 5:42pm
Poulstonb
Thanks
Module sent to Paul so fingers crossed for a positive outcome
Post #960366 2nd Aug 2022 8:14pm
MadTom
Silver box is probably a a boost box to cheat the engine ECU from overboost - look here: https://www.paddockspares.com/turbo-boost-box-td5.html "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #960377 3rd Aug 2022 6:18am
Poulstonb
Yes it looks just like that .
Post #960384 3rd Aug 2022 7:16am
Poulstonb
Evening all
So managed to get the 10AS module repaired by technos , amazing service !!!!!
Front doors are now working on the locking fob but the rear door makes a noise but dosent function .
Should the rear door lock / unlock with the central locking
TIA
Post #963184 28th Aug 2022 5:51pm
Ianh
Yes, as per wiring diagrams above.
Sounds like the rear CDL actuator is struggling to move the mechanism. This could be a High resistance wiring connection, stiff mechanism or weak actuator. Remove the rear door card, oil the mechanism and check electrical connections to actuator as a first step.
Noting that the wiring between the door and the body can fracture so may be damaged but not broken.
Post #963197 28th Aug 2022 8:29pm
