Home > Maintenance & Modifications > window block fitting
NCTT
afternoon all
my 2010 utility is suffering with the window blocks looking very shabby , what are the easiest and relatively cheap options to replace pls ? is this a tricky job , or best to go to a garage pls ?
many thanks in advance as per usual
Post #958279 14th Jul 2022 11:36am
Do you mean the hinge blocks at the base of the windscreen? If so, a search on that term will reveal a plethora of threads about how to replace them and what with. Generally, the solution is something milled from aluminium but there are a range of options at different price points.
Replacing these things is very easy - just a 13mm socket, from memory.
To get you going, here are a couple of links to how I've done it:
My current 110: Hinge Blocks
And my previous 90:
Windscreen Hinge Blocks Part 1 - Preparation
Windscreen Hinge Blocks Part 2 - Installation  Darren
Post #958282 14th Jul 2022 11:55am
NCTT
Ohhh thank you so much
I wasn’t exactly sure what they were called so I really appreciate that
Cheers fella
Lots to be Looking at
Post #958396 15th Jul 2022 7:01am
Dinnu
Need to do this plus the visible part of the bulkhead as it is littered with stone chips that are rusting now 😟
Probably I will try to clean the current screen blocks myself and let a professional painter do the rest. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958400 15th Jul 2022 8:20am
