Home > Maintenance & Modifications > window block fitting |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 |
afternoon all
my 2010 utility is suffering with the window blocks looking very shabby , what are the easiest and relatively cheap options to replace pls ? is this a tricky job , or best to go to a garage pls ? many thanks in advance as per usual |
14th Jul 2022 11:36am |
Do you mean the hinge blocks at the base of the windscreen? If so, a search on that term will reveal a plethora of threads about how to replace them and what with. Generally, the solution is something milled from aluminium but there are a range of options at different price points.
Replacing these things is very easy - just a 13mm socket, from memory. To get you going, here are a couple of links to how I've done it: My current 110: Hinge Blocks And my previous 90: Windscreen Hinge Blocks Part 1 - Preparation Windscreen Hinge Blocks Part 2 - Installation Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Jul 2022 11:55am |
Ohhh thank you so much
I wasn’t exactly sure what they were called so I really appreciate that Cheers fella Lots to be Looking at Cheers |
15th Jul 2022 7:01am |
