Home > Td5 > Fitting the tallies and fatites
Reivilo
South Africa
I'm 6 feet and weigh 140kg, so driving space WAS a little cramped. I removed the window winder and installed front electric windows. Also exchanged the hard indoor handle with a flexible leather belt.
That sorted I extended the driver seat backward 6 cm total. I manufactured 2x flat bar 8 cm length extensions for the front slider, bolted on and down. And 2x 3 cm high shims with longer bolts at the back to clear over the flange (I didn't want to cut through it).
Bob's your uncle!!!
My apologies if someone posted similar in the past - see this as a refresher....
Post #958177 13th Jul 2022 4:31pm
