Fitting the tallies and fatites
I'm 6 feet and weigh 140kg, so driving space WAS a little cramped. I removed the window winder and installed front electric windows. Also exchanged the hard indoor handle with a flexible leather belt.
That sorted I extended the driver seat backward 6 cm total. I manufactured 2x flat bar 8 cm length extensions for the front slider, bolted on and down. And 2x 3 cm high shims with longer bolts at the back to clear over the flange (I didn't want to cut through it).
Bob's your uncle!!!
My apologies if someone posted similar in the past - see this as a refresher....
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
