Home > Td5 > Need to replace radiator - any options..?
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Hi,
After 30+ years of greenlaning in Land Rover/Defender(s) I had to be recovered for the first time on a flat bed trailer.
The cause was a a gashed radiator, caused by something (rock/stick) getting between the fan and the rear of the radiator - see photo.
I'll be ordering a new radiator and wondered if there was any better option than just ordering a standard version..?
Post #957232 4th Jul 2022 10:48am
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
Interesting failure.
Buy a quality pattern part if the original item was meeting the powertrain's cooling needs.
Post #957233 4th Jul 2022 11:29am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I fitted a Nissens one a few years ago. Still does the job perfectly well. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #957234 4th Jul 2022 11:40am
couplands
Quote:
"Interesting failure.
Buy a quality pattern part if the original item was meeting the powertrain's cooling needs."
That's my view too, the original was 21 years old and gave no trouble.
As you say, an interesting failure and there are no marks on the fan blades so not sure how it happened.
Sadly it happened in deepest mid-Wales (Strata Florida) so recovery took a long time - called AA at 08:00 and got home at 20:00.
Comfy ride in the recovery truck though..Wink
Post #957235 4th Jul 2022 11:44am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Your existing rad was fine, and an 'uprated' ally one wouldn't be any more resistant to that type of damage/failure.
If you uprate it without a need to, you're just spending more money for no benefit. And if the same problem happens again, then you'll have just broken a more expensive part.
I'm all for modifying/uprating, but i can't see any point in this scenario.
Go for a quality aftermarket standard part.
Post #957236 4th Jul 2022 11:46am
rallysteve
I always found getting a TD5 to actually warm up in the winter is sometimes hard work. The last thing I would think that would be needed is a more efficient 'upgraded' radiator!
Post #957248 4th Jul 2022 2:15pm
I fitted a Nissens radiator (bought from my local factor) when the genuine LR rad in my Puma started squirting. The Nissens radiator appeared to be every bit as good quality as the original, if not better, and has now lasted longer than the genuine one did.
The TD5 and Puma use the same radiator, by the way.
Post #957282 4th Jul 2022 7:44pm
Ianh
My experience is the same as Blackwolf’s.
I’ve fitted Nissens rads in several vehicles and always found them a perfect fit, very well made and they lasted as long if not longer than the Original rad. Plus they are reasonably priced.
Ps. This is worth a read https://www.defender2.net/forum/post884946.html
Post #957284 4th Jul 2022 7:56pm
