Home > Maintenance & Modifications > Load space mat
thomson_adam
Load space mat
I’m looking at buying a load space Mat as mine is only the small one that doesn’t cover the arches
I was just wondering if the mat comes with the holes so the mat can slide over the tie down points?
https://www.lrparts.net/stc4629-defender-9...-2007.html
Post #956046 20th Jun 2022 8:09pm
jimbo55
Mine didn’t come with the holes for the tie down points
I removed the tie down points, installed the rubber mat and then drilled through from the outside and reinstalled the tie down points.
Post #956051 20th Jun 2022 8:36pm
thomson_adam
Thanks Jimbo , i may have to do this too
Post #956140 21st Jun 2022 7:40pm
Oldowner
Be wary I purchased one of those new for a 90, fitted it and parked it up for 18 months without using the vehicle. In 18 months it had completely fallen apart with no use, it had perished and split along all the creases. I saw the same in a 2014 last week.
Post #956149 21st Jun 2022 8:24pm
thomson_adam
Really ? I see most vehicles still have them in when you look at them for sale on autotrader
Post #956170 22nd Jun 2022 5:25am
spudfan
Ireland
This has been in the back of my 110 2.4 Puma since 2011 and is still in great shape with no rips, tears or signs of deterioration. There are no lashing ring cut outs but there are cut outs for the folding seats.
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #956259 22nd Jun 2022 8:17pm
Oldowner
That is because it is not STC4629! Rolling Eyes
Post #956270 22nd Jun 2022 10:29pm
spudfan
Ireland
Don't know what number it is but it came with the Land Rover as I ordered it with mats. I will look to see if there is a number somewhere on it. Just checked the link above and yes you are right, it is a different animal altogether. It just covers the floor and not the seat boxes. 1982 88" 2.25 diesel
Post #956271 22nd Jun 2022 10:37pm
Oldowner
This was STC4629 purchased new in 2020 after nine months and zero use. It was the second one that I have purchased new which fell apart.
Post #956273 22nd Jun 2022 10:43pm
spudfan
Ireland
That is terrible quality Crying or Very sad 1982 88" 2.25 diesel
Post #956290 23rd Jun 2022 9:05am
NMBRPL8
Australia
Make your own. The OEM gear is Censored
Post #956304 23rd Jun 2022 10:13am
spudfan
Ireland
Our 2008 Puma has a long ribbed mat bought from Paddocks in 2008 and it is still in great shape. It just covers the floor. 1982 88" 2.25 diesel
Post #956306 23rd Jun 2022 10:21am
thomson_adam
Has anyone got a part number for these ?
My 2016 defender has just the inner Mat which doesn’t cover the arches
I contacted JLR parts who said any model after 2007 only comes with an inner mat which I know is not true. Any help would be great
Post #958358 14th Jul 2022 8:22pm
There is two part numbers, one is for a SW with cut outs and a HT version like I have which has no cut outs.
I have the latter and found it was harder to source and find.
This is the mat that doesn’t go over the arches.
I agree that the matting that goes over the arches and seat boxes, gearbox tunnel and footwells isn’t good, it tears and rips purely by removal or by its self! One of the reasons is for some reason it’s thin in places usually in the places where you’d expect strength in the corners as an example..
To add to that the price is astronomical, the annoying part is I like the rubber as it’s easier to clean and avoids moisture and loads of cleaning. Let down by inferior quality. $W33T $0U7H3RN $UG4R
Post #958368 14th Jul 2022 9:29pm
Which type of mat do you want the part number for? You've already identified the one that goes over the arches above (STC4629) but this mat only works with models that have square wheel arches. If yours is a van then that'll fit. Post '07 station wagons have a different rear tub with recesses for seats and this mat won't fit them. Those models come with the centre mat that it sounds like you've already got. Darren
Post #958506 16th Jul 2022 10:40am
